0 Call to undefined method JForm\TfField::set_class_Array()
Martyn Falkous
26%
Hi,
When I click on "test" I get the following error:
0 Call to undefined method TechFry\Library\View\JForm\TfField::set_class_Array()
Can you help please
Thanks
Marytn
Thank you for informing about the issue. We are working on it. A new version of the component will be released tomorrow.
Martyn Falkous
26%
November 06, 2023
Thanks for that and all working correctly now, just one more question, when we translate "go to course" it does not change and the same if I edit the English file....
Thanks
Martyn
You can edit the "Go to Course" text directly in the menu options for TF Learn -> Paths.
Unser the options tab, there is setting for Course Button Text.
Martyn Falkous
26%
November 06, 2023
Perfect, thank you!
Martyn Falkous
26%
November 07, 2023
Hi again!
When we go to scores, it tells us the correct answer (which also I cannot see where to translate) but it does not indicate the answer the student missed, is there a way of doing this please?
Thanks
Martyn
Please update the component. Both issues are now fixed.
Martyn Falkous
26%
November 08, 2023
Hi,
Thanks for the reply, I have updated the component and the library and the translation issue is fixed, I cannot see how to let the student see the answer that they selected or was incorrect still?Can you help please?
Thanks
Martyn
Martyn Falkous
26%
November 08, 2023
Hi,
Sorry I see that it is working, my fault
Thanks for your help
Martyn
