A few questions
Florin Gaibar
50%
  • TF Shop
April 18, 2023
Hi,
For TF Shop
I can list products in columns. Can you make to list products using columns and pages? To have for example 9 products (in 3 columns) on page with more pages, depends on number of how many products I have it.
Search works for information in the title. Can I look up information from the product description label, features label and title? There may be more information than only in the title.
About image for products, can I post an image only for the product? I don't want to publish the image in the main menu with all the products. The page become too crowded with too many images. And I have the same image to show and is not pretty.
For pages, currently component uses default list limit. Will add in the component options. Thank you for this suggestion.
For search, do you want to display different input fields or one input field for searching in title or description?
For image in list of products, there is setting in component options, under Products tab - Show Image. You can disable this.
Florin Gaibar
50%
April 18, 2023
I had 15 products on page, now I see that at 20 products it is create the page 2. Not bad… just for a mobile preview it can be o list too long, but is not bad.
For search it can be good one field input to search both in title or description.
I have disabled the setting in Options > Products (These settings apply for products page.) > Show Image to Hide. But when I put an image in product Media field, this image is taken in both displays (on menu and on a single products). It should be only for a single products.
The image issue is now fixed. Please update the component.
We are working on the search to include description as well.
