Articles Joomla Module: no
Roby
22%
  • TF Articles
December 21, 2022
Hi, I bought yesterday the "Articles Joomla Module" and looking at the demo from your site I don't understand how to make the transition/effect on the intro image when I place the mouse over the intro image in my home page.
In your demo if I go with the mouse over the image it turns from gray to color: how should I set the module?
December 21, 2022
Under the Styles tab, you can select transition effect on the Card or Image or Both. Also, set the duration for smooth transitioning.
Which Joomla template are you using?
Roby
22%
December 21, 2022
Hi and thanks for the answer: yes I set it as you say but unfortunately it doesn't work!
I'm using the free template "Shaper_helix3".
Do you have any suggestions? Thank you
December 21, 2022
Please update TF Library and Articles Module.
In the module settings under Module Tab, Load Resources -> Select Air Animation CSS.
Let me know if this works.
Roby
22%
December 21, 2022
Hello, thank you very much! Now works...
Definitely needed to upgrade first. Thank you
Roby
22%
February 07, 2023
Hi friend and sorry for the inconvenience. I wanted to ask you for advice on how to display the "read more" again, which now no longer appears!
Unfortunately I must have changed some settings and the "Read More" button no longer appears in the articles.
These are the settings in your component and I have enabled the display of the "Read More" in the articles settings, so I don't understand why the button does not appear. can you help me?
February 07, 2023
Under the Styles tab, there is a Field Button Text. Enter "Read More" or some other text like "Continue Reading" to show the Read More button. You can also add button class like: btn btn-primary.
Roby
22%
February 07, 2023
Perfect friend ;)
Nice to meet you :)
