Brakes joomla 4
  • TF Shop
May 10, 2023
Hi I've installed the free version of TF Shop before I buy the pro version.
I created a menu link from the top main menu bar to 'Products' and it gives errors. when you select a product it brakes the site?
Have I missed something during setup or config?
see attached for location of link.
regards
Bob
The error indicates that component is not found. maybe it is not installed properly. if possible, please email Joomla login details to mail@techfry.com, so that I can investigate the issue further.
