Errors with accordeon in TF Widget (and TF Pagebuilder)
Filip
- TF Page Builder
June 02, 2023
I created a module type accordion with TF Widget but get a bunch of warnings.
Most of them (the undefined array key "" lines) can be solved by changing the Section parameters, which are set to none by default, for the widget.
Then only the last warning (undefined variable $container) rests.
With the page builder, setting up an accordion, I get almost the same warnings (the undefined array key "" lines) but there I can't set those parameters.
Also with the widget the accordion is working, but not with the page builder, there I can't open the other items.
Filip
