Fields in Forum
Florin Gaibar
50%
1. Hi, I really don't know how to use fields for forum (in new topic, in reply). I only be able to create a radio field with 3 variants for new topic. I consider it should be easy to use fields in all ways :)
I need field text for example, and I can not use it...
What I am doing wrong?
2. And for a new topic it was not possible to attach a picture jpg.
There is some issue in custom fields. We are working to solve this.
Will update the component in couple of days.
The issue is now solved. Please update the component and Library.
