Forum access level
Eddy Brix
Hi, I set the access level to PUBLIC in General settings > TF Forum > Topics & Topic
but the Forum still asking for " Login to Reply"
What I have done wrong ?
December 02, 2022
This was some issue. Thank you for reporting it.
We have solved it now. Please update the extension. In the component options, under New Topic Tab, set Access to Public.
Eddy Brix
Thanx for the quick reply, but I cant write to the fields neither name nor email and also not in the comment field
https://www.wwl.lu/index.php/forum-test-1/test-3
December 02, 2022
Please update the extension again to the newer version. This will solve name and email fields.
For comment or message, are you using JCE editor? In the component options, under Reply Tab, set Enable Editor to "No" and then try again.
Eddy Brix
YES everything works fine now ;-)
Best regards,
Eddy
Eddy Brix
Hi, its me again ;-)
when I write a reply, my name is not displayed.
December 03, 2022
I think this is the issue when guest user is replying. We are looking into it.
The component will be updated in 1 to 2 days.
