How to allow users to edit or delete their replies in TF Forum?
Yanting Liu
I would like to allow users to edit their replies but I'm not sure if TF Forum provide this feature.
I found this TF Forum > Options > Reply Form > Enable Editor  and I turned it on but nothing changed.
Does TF Forum offer editing replies feature and how does enable editor that I mentioned above work?
Thank you.
April 27, 2022
TF Forum doesn't have such feature to edit reply from the front-end.
The "Enable editor" field allows to add reply through the editor like TinyMCE. You can define this editor in global configuration.
