Lesson completion issue
Tonatiuh Maldonado
28%
Hello there.
I update my component from 1.3.7 to 1.3.8 and everything work´s fine, apparently, till users reported me that one lesson isn´t marked as complete; option "mark as a complete" is not available.
No problem because y review it an marked manually, but i don´t know why is this happening. The course has 2 lessons. One of them works fine, but other one no and both have the same configuration.
I attach de config image and error.
Thank´s
Tonatiuh Maldonado
28%
May 11, 2021
Hiii
Strange but right now one user takes the lesson and it works fine. No error. I dont know why but i´m monitoring it and waiting for the feature where you can set percentage score required to mark lesson as complete.
One more question. can you tellme how to obtain this?
  • Access to Downloads: Tips, Guides, Tutorials, and Graphics.
  • Acces to BootOne joomla template.
  • Get certification on completion courses.
I´m a premium member i´m interesed in certification on completion courses, guides and graphics.
Thank´s
May 12, 2021
For lesson completion issue, set completion type to "Self" so that students can manually mark the lesson as complete.
May 12, 2021
The percentage feature for lesson completion will be released in couple of days.
You can download the BootOne template from here: https://www.techfry.com/joomla-extensions?view=product&id=5
The download section (for guides, tutorials, and graphics) is undergoing some changes. It will be again available in next 4 to 5 days.
The certification system is under development stage. It will be ready in 2 to 3 weeks.
We are also working on new question types and making our extensions future-ready for Joomla 4!
May 12, 2021
Now, the percentage requirement for lesson completion is included. Please update the extension!
In the lesson, under options, you can add minimum percentage required for the lesson to mark as complete.
Tonatiuh Maldonado
28%
May 12, 2021
Hello.
Thanks for the update. It works fine. I download BootOne template but the file it´s empty.
May 12, 2021
Try downloading the template now.
