"Load Bootstrap" option not working in TF Learn
brett vac
Hello, I am using the most recent version of TF Learn.
In Global Configuration, there is a drop down menu with options to add bootstrap.
However, if I select any of these options (for example, CSS), my courses won't display.
More precisely, the "paths" menu item causes an "error:0" This page cannot be displayed.
Furthermore there is the following error:
Call to undefined method TfLearn\Site\View\Courses\HtmlView::add_bootstrap()
I would like to load bootstrap for TF Learn because my template doesn't load it by default.
Thanks.
June 03, 2022
We are looking into it. Will provide update shortly.
June 04, 2022
Please update the TF library and check now.
brett vac
June 05, 2022
Very nice. Thanks!
