Possible bug using path?
Ronald Spierings
22%
Joomla version: 4.3.4 TF Learn version: 2.1.1 (light version) Tech Fry Library version: 2.4.2
Situation: Only one course present and set to user group "registered" Enrolment to "none" or "self" User added to enrolment course Menu item set to path
Problem: When using menu item "path" and present logged-in user is not assigned to the user group "registered" you will get the following error: The requested page can't be found. Error code: Object of class stdClass could not be converted to string
September 03, 2023
I am not able able to reproduce this issue. Please enable Debug mode in Global Configuration. Then, it will show where is the exact problem.
Thank you.
Ronald Spierings
22%
September 03, 2023
Thanks for your reply.
Used the debug function already. It seems that when I assign a user toe a course, this problem occurs using menu item type path. No results found when using a menu item type course (all).
Debug info:
Object of class stdClass could not be converted to string Call stack # Function Location 1 () JROOT/components/com_tflearn/src/Model/PathsModel.php:39 2 implode()
September 03, 2023
Thank toy for the details. Please update the component. This should be solved now.
Ronald Spierings
22%
September 03, 2023
Thx. After the update it seems the problem is solved.
Regards,Ronald
