Products sorting/reordering
Pierrick LE BRUN
Pierrick LE BRUN
April 22, 2022
In TF shop options => Orders => Order column => I chose 'modified'
and then => Order direction => (choose either ascending or descending depending of the goal to achieve)
And then do a fake modification to the article you want to go on top or on the bottom of the list (depending on the direction you set in the previous step.
I'd say it's better than no solution, even though a bit convoluted.
Basically, the best is to know and plan the order of the products ahead of time (and hope you won't have to modify it later on)
L I put my orders URL and all is as expected now, even the success message is shown now.
