Selected article in Content ID under Lesson not working properly
wasim raja
6%
Hi,
Thanks a lot for TF Learn Components.
I am facing some issues, related to lesson content. Some code like "{pdf=images/sm/irdai/l-1/irda-l-1.pdf|100%|1030|google}" is not working through the Lesson content ID in Lesson-1, but the same content through the menu is working perfectly.
Article URL through TF Learn Lesson: http://stweds.com/index.php/mcqs-practice/mcq-for-irda/irda-lesson-1?view=page&course=1&id=1
Article URL through Menu named Test: http://stweds.com/index.php/test-content
The same article is used in both URLs. The Code "{pdf=images/sm/irdai/l-1/irda-l-1.pdf|100%|1030|google}" is Not working in the article through TF Learn URL but the same code is working perfectly in the article through Menu URL.
Kindly suggest to me, what is the issue and how to resolve it?
Thanks a lot
Warm Regards:
Wasim raja.
February 13, 2022
I think you are using plugin for embedding PDF documents. You need to enable "Prepare Content" in the component options under Page tab.
wasim raja
6%
February 17, 2022
Hi sir, Thanks a lot for your reply. I have enabled "Prepare Content" in the component option under the Page tab. But it's still not working. When I am trying to use other code like iframe, it's also not working. Please suggest me for further. Thank you.
February 18, 2022
For iframe tag, you chane TinyMCE plugin settings under prohibited elements.
Which plugin you are using foe embedding PDFs?
Wasim Raja
Hi, I am using "Embed PDF" plugin package for PDF file. i am also trying to use an another code like: But not working properly. Please assist me for that issue. Thanks a lot Warm Regards: Wasim Raja
February 26, 2022
Instead of embedding PDF, there is option to add the pdf link in the lesson options. This way, PDF document will open instead of lesson content.
