Strict Routing with the SEF plugin breaks TF Learn Routing
brett vac
If I set Strict Routing to Yes using the System - SEF plugin, causes Joomla to not use my assigned TF Learn Paths menu item.
Without strict routing enabled, the path url when I click on the "Go to course" button looks like this:
mysite.com/test-tf-learn-path?view=page&course=1&lesson=1&id=1
But with the strict routing enabled, the path URL after clicking on "Go To Course" now looks like this:
mysite.com/component/tflearn/?view=page&course=1&lesson=1&id=1
The expected result would be that the strict routing plugin, introduced in Joomla! 5.2 does not cause TF Learn to lose the dedicated menu item that I set.
Thanks in advance for your attention,
Brett
October 21, 2026
Thank you for informing about the issue.
We are looking into this.
