Test Results and Question Explanations
brett vac
Hello, I have two requests regarding the "Scores" menu option in TF Learn.
When viewing the test results, the Correct Answer badge is displayed next to the correct answer in a multiple choice text even if the user got the question wrong. How do I hide this badge?  In the test results page, I thought the "explanation" was to appear next to the correct answer in the test results page. However, this doesn't seem to be the case. Where can I access the text that I enter into the "explanation" box in the questions tab?
Thank you for your help.
Please update the component. Both issues are now solved.
You can enable or disable showing correct answers or explanation from the component options -> Score Tab.
Correct Answer badge shows the actual correct answer to the question. Green Tick mark shows the question was answered correctly. Red cross mark shows the questions was answered wrongly.
brett vac
March 07, 2023
Exzcellent. Thanks.
