TF Learn Courses view not appearing in columns
brett vac
Hello, The "Columns" option under the TF Learn > Courses menu item doesn't appear to be working.
Under previous TF Learn versions, you could set a number of columns between 1 and 4 and the output in the source code would reflect that. For instance, if I choose 2 columns I would get
But under the current version of TF Learn (2.5.3) I can choose any number of columns from 1 to 4 and get: This causes the courses to all be displayed in the same row. I am hoping you can bring back the feature to control the number of columns in a future update.
Thanks in advance,
Please update the component. This issue is now resolved.
