TF Upload 2 problems
Kostas kolokotronis
- Custom Fields
November 12, 2025
Hi, i noticed 2 problems.
1. I tried to use TF upload on user registration but upload button is disabled. Is is not working for security reasons?
2. If I set required TF upload custom field it works only on one article. On all others don't work. I must remove required setting from custom field options
Thanks
Please check the permissions while editing the custom field. The "Public" access should be allowed.
If this doesn't work, please send Joomla credentials to mail@joomlafry.com
Kostas kolokotronis
