tf upload problem
LY
The size set at the back-end is used for checking while uploading the submitted file.
To change the text, you can create Language Override. Please navigate to System > Manage > Language Overrides.
Select language and client. Then, change the language constant: JGLOBAL_MAXIMUM_UPLOAD_SIZE_LIMIT
To remove it (not to display anything), you can leave the text empty.
