TF Learn errors on installation
Darius
Please install TF Library. You can find here: https://www.techfry.com/joomla-extensions
Darius
There is no need to extract zip file. Just install the extension using standard Joomla installer. Alternatively, you can send login credentials to mail@techfry.com
We will install the component.
