Warning after installing TF Content Pro and TF Library, one database problem
bold
48%
April 07, 2026
1) Installed TF Content Pro and TF Library
Extension Version: 2.8.7 Pro
Joomla Version: 6.0.4
PHP Version: 8.4.18
2) Navigated to Admin > TF Content > Dashboard
3) Result, three warnings are displayed:
Warning: DOMDocument::load(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /home/mywebsite/public_html/libraries/techfry/src/Model/Back/TfModelDashboard.php on line 68
Warning: DOMDocument::load(https://updates.joomlafry.com/components/tfcontent.xml): Failed to open stream: no suitable wrapper could be found in /home/mywebsite/public_html/libraries/techfry/src/Model/Back/TfModelDashboard.php on line 68
Warning: DOMDocument::load(): I/O warning : failed to load external entity "https://updates.joomlafry.com/components/tfcontent.xml" in /home/mywebsite/public_html/libraries/techfry/src/Model/Back/TfModelDashboard.php on line 68
Separately, I reported this issue last October, it still persists (see attached image):
https://joomlafry.com/forum/joomla-update-of-database-for-tf-content-shows-one-problem
One Problem
Table 'josmu_tfc_tasks' has the wrong type or attributes for column 'COLUMN' with type `trigger`. (From file 2.7.2.sql.)
14 database changes were checked.
3 database changes did not alter table structure and were skipped.
If possible, In the PHP configuration, please set allow_url_fopen = On
We are working on alternate way, so this will work even without it.
