Wrong code cause test failure
Kósa Bence
8%
On the following file com_tflearn/src/Model/TestModel.php on line 128-133 is wrong the correct code is:
// Mark completed if completion type is score and percent achieved
if ($lesson->completion_type == 'score' && $percentage >= $lesson->pass_percent)
$ch = new Completion([
'lesson_id' => $data['lesson_id'],
'user_id' => $data['created_by']
$ch->change_state(1);
and also there is a missing line under 21 (use lines)
use TechFry\Component\TfLearn\Administrator\Helper\Completion;
After that it is not sending if the test is successful
Cheers
July 01, 2026
Thank you for informing about this error in the code.
We have now corrected this now.
