Course Display not working in TF Learn 1.4.4
Guest
51%
Hi,
The menu item to display all courses (Menu Item TF Learn » Paths) doesn't work in the most recent version of TF Learn, 1.4.4. No courses are displayed.
I've had to roll back to version 1.4.3 which properly displays all the courses.
Thanks.
I have checked the issue. the ordering may not be working.
Visit the configuration, under Courses and Paths tab, select the desired order column and order direction. Then, save the configuration.
6%
June 16, 2021
Uh oh. I am unable to upgrade to 1.4.4 from 1.4.3.
I believe this is due to the fact that I have questions linked to lessons in my courses but I haven't specified Content IDs for these questions.
Here is the error that appears when I attempt to install the extension:
JInstaller:: Install: SQL error Can't DROP COLUMN `qsource`; check that it exists
Extension Update: SQL error processing the query: DB function failed with error number 1091
SQL =
ALTER TABLE `#__ tfl_lessons` DROP COLUMN` qsource`;
Please let me know if you require that I open another ticket.
The error is because the extension was updated earlier and then while updating again, it is unable to run database queries.
Specifying content IDs is no longer required now. The extension takes questions automatically.
I am sending you zip file by email. Please try updating extension using this file.
6%
June 16, 2021
I've uploaded the modified ZIP without database queries and changed the order column to "title". This works properly. Thanks for your help!
