How it works TF Structured Data?
- TF Structured Data
Hello, could you tell me how TF-Structured-Data works? It’s only possible to select in the Plugin ‘Custom Schema’ and ‘Category’. Where, for example, do I enter the ‘startDate’ field? Surely it needs to be assigned?
I’m using Yootheme Pro and Joomla 6 – how do they work together?
I can’t find any documentation. All the other extensions have documentation - just not TF Structured Data.
Can you help? Thank you
Hello, there are custom fields – e.g. ‘startDate’. How can your TF Structured Data plugin be configured to connect to these?
As I’ve already explained, the plugin only allows me to select a ‘schema’ – e.g. ‘Event’ – and the category. There’s no more option to display or map custom Joomla fields.
I’d like to use your plugin dynamically with YooTheme Pro.
I’d need some documentation for this...Can you helo?
The plugin will automatically use custom fields based on the name of the custom field. For example, use "start" as name of the field for startDate.
Here is the link for documentation:
https://joomlafry.com/documentation/tf-structured-data-documentation
Documentation link is shared above in this topic.
Please share Joomla credentials at mail@joomlafry.com, we can setup the plugin if there is any issue.
We will provide a refund in case plugin is not working.
