Load plugins in TF Learn Course page
brett vac
Hello, I would like the ability to "prepare content" in the TF Learn course page.
Currently, I have an article that has all the sales copy for my course that I created in TF Learn.
In TF Learn -> Courses, under the course description, I simply load the article using the Articles Anywhere plugin. But the plugins inside the article don't work.
For instance, the load modules plugin just appears as text, like this
{loadmoduleid 153}
I would like to have the module load or at worst just have that text hidden.
If you would integrate this feature request into your future versions I would be much obliged.
Thanks!
There is a setting for enabling content plugins in component options -> Page Tab -> Prepare Content. Please enalble this.
brett vac
November 17, 2023
Hello, thanks for the reply.
That enables plugins in the course pages; I already have this option enabled.
I am talking about enabling plugins on the course landing page; the one that is publically viewable through the menu item TF Learn -> Paths
Currently it just shows something like {loadmoduleid 155} if I attempt to load a plugin. I would like the plugin to display or the text to be hidden if it can't. I hope you are able to implement this feature.
Thanks,
Brett
Thank you for the suggestion.
We will include this in the next update in 2 to 3 days.
brett vac
November 20, 2023
Great. Thank you.
brett vac
January 26, 2024
Hello, I am writing because I don't think this update has been properly implemented.
I currently have TF Learn 2.2.4 and the only thing that displays is the curly brace text when I attempt to load a plugin, for example:
{vimeo}https://vimeo.com/123123123{/vimeo}   Where in the article this plugin would load the video.   Thanks and looking forward to your update.
Where exactly this short code is entered in the backend?
brett vac
January 27, 2024
In the course:Edit page at index.php?option=com_tflearn&view=course&layout=edit&id=1
Please update the component and check now. There is new setting in global configuration under course tab for "Prepare Content". Please enable this as well.
brett vac
January 28, 2024
It works. Thank you!
