Plugins not working inside TF Learn articles
Guest
51%
I am using TF Learn to organize and present my course. The lesson content is pulled from regular Joomla articles. I am using the AllVideos by JoomlaWorks plugin to load videos in my articles. The plugin is loaded by using the code {youtube}0u_g6zNuP_I{/youtube} in the article, for example.
This plugin works fine if the article is displayed normally, but it won't load when the article is loaded through TF Learn. Instead of the plugin loading, the curly brace text is displayed.
Is there an option I can use, sort of like the 'prepare content" option to use when loading plugins inside modules? I would like to use the AllVideos plugin instead of putting iFrames in my articles, for example.
Thanks.
Thank you for the feedback. Currently, plugins are not triggered. It will be a nice feature!
We will include in the next update coming in 2 to 3 days.
10%
May 05, 2021
Thanks! Very nice extension btw ?
10%
May 05, 2021
May I suggest another modification:
The Enrol Button Text option doesn't seem to be working under Menu -> Courses
The buttons always say 'Enrol Now' on the course page.
10%
May 05, 2021
Also, another feature suggestion:
Once I finish a lesson in a module, there is no easy way to jump to the next module.
A nice feature would be to have a button that lets you go to the next module or go back to the course homepage, instead of having to click the back button.
If there is an easy way to do this please share.
Thank you in advance for your attention!
The "Enrol Now" Text can be changed from language files. Navigate to Extensions -> Languages -> Overrides. Here, you can create an override for the text.
It was earlier taken from the menu options. Will remove from there now. Thanks for informing. :)
We have added the feature to load plugins for Joomla articles. You have to enable it in the Configuration -> Page -> Prepare Content.
10%
May 08, 2021
Nice. Thanks!
