Some problem for the TF Forum
LY
20%
Hi!
I have just installed and configuring the TF Forum. I found that there is no logout button after I have login to create new topic or reply topic.
Besides, most of the words cannot be found in language override, what should I do? Or which document I can customize the words?
Thanks for help.
1. For logout, you can create Joomla menu item for Users > Logout.
2. Please share the words which are not available in language overrides. We will add them.
LY
20%
March 13, 2024
Thanks!
Words not available in language overrides:
On the All Topics page:
SEARCH, Title, Description, Started by XX on, Replied by XX on, Subject, Replies
On the Create Topic page:
Your Name, Your Email, Subject or Title, Captcha, equals, WORDS
On the individual topic page:
Forum, LOGIN TO REPLY, ALL TOPICS
You can create language overrides for following:
  • COM_TFFORUM_REPLIED_BY
  • COM_TFFORUM_STARTED_BY
  • COM_TFFORUM_SUBJECT
  • COM_TFFORUM_REPLIES
  • COM_TFFORUM_TEXT_FORUM
  • COM_TFFORUM_TEXT_LOGIN_REPLY
LY
20%
March 21, 2024
Thanks!
LY
20%
March 22, 2024
Hi! Where can I change the words SEARCH, Title, Description on the All Topics page?
https://dw.729ly.net/list-all-topics
For search, you can create override for: COM_TF_BUTTON_SEARCH
For Title and Description placeholders, we will update the component to include these as language strings as well. The component will be updated in 2 to 4 days.
LY
20%
March 25, 2024
Thank you so much.
Another problem is that I have added a field for topic to attach files. However, it shows internal server error.
What is the possible problem?
Thanks for help.
Which plugin or custom field is used for file attachments?
LY
20%
March 28, 2024
I added the field in "TF Forum: Fields" and choose the type "media".
Please enable debug mode from global configuration. It will provide more information where the problem is.
LY
20%
April 09, 2024
Hi! As you mentioned that "For Title and Description placeholders, we will update the component to include these as language strings as well. The component will be updated in 2 to 4 days.", how is the progress? Where can I update it?
Even if I enable the debug mode, no new hints shown. Besides, I found that in your site, upload file let user to select files from own computer, but for my site, it let user to select files from the server folders. They are different.
For language strings, please update the library and click Install Languages from component dashboard.
Then add override for COM_TF_SEARCH_TITLE and COM_TF_SEARCH_DESCRIPTION
For file uploads, we are using File Upload Custom Field - https://www.techfry.com/joomla-extensions/file-upload-joomla-custom-field
You can use any other similar file upload custom field from JED as well.
LY
20%
April 09, 2024
What do you mean by "update the library"?
Update TF Library. I can be downloaded from here: https://www.techfry.com/joomla-extensions
LY
20%
April 10, 2024
noted with thanks!
frankhsu
8%
April 11, 2024
Hi, I'm having a problem on the TF forum.I started the discussion in Chinese. I followed the steps in the video to create it, but when I entered my message and content and clicked "Submit", instead of being directed to the actual page like in the video, the page was not found. This problem also occurs when I send messages. After creating a discussion in Chinese, it cannot be directed. I click the button to return to the homepage. When I go back to the forum I see that my post was indeed sent, but when I click on the discussion title I can't get to my discussion page. However, when I create it in English and numbers, it works. It can be used normally. I changed the Chinese title to English in the administrator interface and it was successful. I also used the admin interface to change the English title to Chinese. The problem is that I cannot create a Chinese title that can be clicked into the online discussion. Is there any way to solve this problem?
