TF Content: Tag values not being saved in record
bold
48%
  • TF Content
April 30, 2026
Steps to Reproduce:
Create a Content App
Create a Column type Tag
In Field Settings tab, enable Multiple
In Display Options tab, select Display Type: Badge
In the Content App, create a new record
For the Tag column, select Tag(s)
Save the new record, examine the Tags field after the page refreshes
Expected:
The selected Tags to be displayed
Result:
No Tags are displayed, It contains no values, no Tag information has been saved
Note:
Because of this, no Tags are displayed in the frontend view of the record.
Thank you for informing about these issues. We are working on these.
bold
48%
May 08, 2026
Thanks, I appreciate your help.
The tag issue and the image issue (https://joomlafry.com/forum/tf-content-image-column-not-displaying-image) are blocking me from publishing a directory for a client's site.
Resolution for my mailto: prefix problem would also be great, but does not prevent publishing.
The tag issue and image issue should be solved. Please update the component and TF Library.
We are working on email link issue.
bold
48%
May 08, 2026
I will give it a try - thank you for the update and for all your hard work!
bold
48%
May 09, 2026
Unfortunately the image problem is unchanged. I don't know if that Column requires other settings changes to display the image instead of the image path.
There is some progress with tags. However, instead of discreet/separate badges with tag names, the output looks like:
{"0":"2","1":"8","2":"13"}
And this badge is not linked either. I assume that the Item View needs an entry (or entries) in the Join Tables tab, similar to Categories.
Maybe a Join Tables entry needs to be defined in order to display image instead of image file path?
Any guidance is appreciated.
Hello, please update the component and library. This should fix the Tags issue and prefix issue.
For image, under Display Settings, please enter URL Prefix like images/ (If you are using directory or folder under field settings, add that too).
Let me know if this works.
bold
48%
May 11, 2026
Thank you so much for your help!
Everything works now except the Tags are not links, only static badges.
How do I get them to behave like standard Joomla Tags?
bold
48%
May 19, 2026
Hello, is there any word on this?
Can TF Content display tags that link to a list of other tagged Joomla content?
Thank you for your time
The request has been forwarded to development team.
We will release a new version in couple of days.
bold
48%
May 20, 2026
Excellent, your team is great!
Please update the extension. Now, tags should be linked.
bold
48%
May 30, 2026
This appears to be working now, but just a quick note: all tag values are preceeded by the symbol #
For example, the tag Classes displays as
# Classes
Ideally there should be no hastag
Thanks again for all your hard work. I created a streamlined directory that is 99% less complicated to use than something like RS Directory or J-Business Directory.
Cheers
bold
48%
June 19, 2026
I may have spoken too soon.
I've updated the Content App with records and and assigned tags to all of them.
But when I go to the Item View and click on a tag, it produces no results.
For example, I have tagged several records with the tag "Community"
Clicking on the Community tag redirects me to the following page, which is empty:
(my website URL)/component/tags/tag/community
Could this be a TF Content issue, or could this be another configuration issue with Joomla tags?
