Using Joomla's native tags as a TF Content colum
bold
48%
  • TF Content
February 27, 2025
Is there any way to use Joomla tags as a column type in TF Content? I would like my records include tags, so Users can click on them to list other TF Content records with the same tag.
Thank you for your time
-Chris
bold
48%
March 04, 2025
I created a new column in TF Content, in field type I chose SubformThen I created an XML subform with the field type: tagsAnd uploaded it to /libraries/techfry/forms/content/tags.xml
This allowed me to add a tag to a record, but when I tried to submit the record I received an error1146 Table 'cleunited_joom759.josub_tfc_' doesn't exist
Maybe there's another method to include Joomla tags in TF Content records?
bold
48%
March 06, 2025
I was hoping to buy TF Content, but if there isn't a way to us Joomla tags as a column type, I need to find another solution. Can I get an answer from one of the developers, please? Thank you for your time.
We have forwarded this request to the development team. A new tags field is in the development.
Meanwhile you can try using SQL field type.
bold
48%
March 06, 2025
Awesome -- thank you TF team!
bold
48%
March 06, 2025
Sorry to bother again. I can't find documentation on using the SQL field type to allow tags.
In Column > Field Options > Field Settings
I have set the field Type to Sql
Below that, under Field Settings there are the following fields:
Options Select From Where Group By Order By Key Field Value Field Header Multiple Form Layout
Which. if any, paramters do I need to add to these fields to invoke Tags? Thank you for your time
bold
48%
March 10, 2025
Hi again, is there doumentation for configuring these Field Settings for Joomla Tags when the column field type is set to SQL:
Options
Select
From
Where
Group By
Order By
Key Field
Value Field
For displaying Joomla tags, you can enter following:
Select: id,title
Order By: title ASC
Key Field: id
Value Field: title
Header: Select Tag or anything
bold
48%
March 19, 2025
I tried these settings, when I navigate to the "TF Content > Create Record" menu item, I recieve the following page error:
1146
Table 'cleunited_joom759.josub_josub_tags' doesn't exist
bold
48%
March 22, 2025
Do you know if this is a bug, or if I am missing parameters/values in my configuration?
Is there a time estimate on when the new tag field will be ready?
Thank you for your time!
bold
48%
March 26, 2025
Hi, any update on this?
The fact that the error says "josub_josub_tags" suggests a PHP file is repeating the variable for table prefix (josub_)
And if it was corrected, the component would be able to locate and display data from "josub_tags"
I can make this change myself if you can tell me which file/line needs to be updated.
Any help is appreciated.
bold
48%
April 08, 2026
I see that TF Content is now has Tag as a column type.
However, after creating this column type, I am only able to add one tag for a record.
Is there a method/configuration for allowing multiple tags to be selected?
bold
48%
April 13, 2026
Aha! I found the option to select Multiple in the Field Settings tab of the Tag column. Problem solved!
